Activity › Forums › Apple Final Cut Pro Legacy › compreesor batch monitor freezing
Posted by Tony Hancock on December 1, 2010 at 4:35 ambatch monitor keeps freezing how can i fix this problem and my footage like 2:25:00
Jerry Hofmann replied 15 years, 10 months ago 2 Members · 1 Reply -
1 Reply
Jerry Hofmann
December 1, 2010 at 5:29 pmIf your compression is stopping, so will the batch monitor. Sounds like the file you’ve sent to compressor has corrupted media in it. It’s likely the clips which are the same percentage in from the front of the sequence that the Batch monitor gets to. So if it stops about 50% in, look at the area of the sequence 50% in and try re rendering or rebuilding that section of the sequence.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
