Activity › Forums › Adobe Photoshop › Composting Photo with Black Bg onto Black Background for print?
  • Composting Photo with Black Bg onto Black Background for print?
    Posted by Llll–kia on February 10, 2006 at 11:25 am
    I’m designing a set of DVD covers where the feature photos on the fronts covers have black backgrounds. I have adjusted the levels of the photos so that the blacks look the same as the full black background. However when I combine the layers and increase the brightness (only to check how close the match is) you can still see a difference between the two. I have tried fading the edges of the photo into the background but I am still concerned when this goes to print that the two different tones of black will show up.
    Any suggestions would be much appreciated
    Jeff Kelley replied 20 years, 7 months ago 2 Members · 1 Reply
  • Jeff Kelley
    February 13, 2006 at 11:21 pm
    What program are you doing this in? Photoshop? If so, just take a sample of both blacks. if they are the same CYMK values, you’ll be ok. You can’t do it by sight.
