Activity Forums Maxon Cinema 4D composting objects in layers to AE
  • composting objects in layers to AE
    Posted by Tom Hall on November 17, 2008 at 5:41 pm
    is there any way to send my shot out to AE with my objects in layers. like if i have a shot of the camera going around a cube a ball and a cone, can i send it to AE and turn the cube channel off of just put a blur on the ball?
    thank you
    cinema 4d
    Tom Hall replied 17 years, 9 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    November 17, 2008 at 8:52 pm
    Yes, but you have to set up object buffers. What you do is give each object you want separated a compositing tag and then check one of the boxes in the object buffer tab.
    Then add the corresponding object buffer passes in the render>multipass settings.
    In AE, use the buffer passes as track mattes to separate the objects.
  • Tom Hall
    November 17, 2008 at 9:09 pm
    sweet .. thank you i well get on that
    cinema 4d
