Activity Forums Adobe After Effects Composition was scaled up when rendered?
  • Composition was scaled up when rendered?
    Posted by Josh Krauth-harding on August 7, 2014 at 3:06 am
    Although I’m not new to AE, I would say I’m a beginner… so go easy on me! I’m guessing I just did something pretty dumb, but I need help none the less!
    Recently, I rendered a composition to a .avi and I was met by some terrible quality. This confused me, because inside of After Effects, things seemed nice, and looked good. However, here’s a screenshot (using ShareX) I took inside of After Effects of some text:
    Here’s it in Windows Media Player:
    You can tell that the quality of the second picture is lower, while the size is bigger. Perhaps I just wasn’t viewing it at the correct aspect ratio inside of After Effects, and if this is the case, how can I change it so the quality looks good once I render?
    Thank you!
    Graphic/Motion Designer in Training… lots of training.
    Michael Szalapski replied 12 years, 1 month ago 3 Members · 2 Replies
  • Tero Ahlfors
    August 7, 2014 at 8:22 am
    Is the WMP window the same size as your AE comp window?
  • Michael Szalapski
    August 7, 2014 at 3:44 pm
    What Tero asked. Also, what were your render settings in AE? What were your composition settings?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
