Activity › Forums › Maxon Cinema 4D › Composition tag on material – is it possible?
Posted by Richard Quinn on August 19, 2009 at 9:26 amHi,
Is it possible to add an composition tag to a material? I have a hat with a star texture. The stars are a gold material with an alpha channel.
I want to add a post effect highlight to the stars. I know you can add an object buffer to an object but is there anyway you can do a similar thing to a material.
Cheers,
Rich
Richard Quinn replied 17 years, 1 month ago 2 Members · 6 Replies -
Richard Quinn
August 19, 2009 at 2:25 pmHi Adam,
Thanks for the prompt reply.
How could I achieve this with 2 renders?
How can I make only the stars render on there own if they are wrapped around the hat object.
I just tried applying a luminance channel with 100% white to the area around the stars thinking that might render out as an alpha. However the post effects could see it and the highlights went crazy.
Cheers,
Rich
Adam Trachtenberg
August 20, 2009 at 6:01 pmWhat I would do is create a separate material of just the stars in the luminance channel — white on black. Apply it to your object and render out a material:luminance pass. Delete all of the other materials from your scene. In fact, you can delete all objects that don’t pass in front of your object to speed up the render. Then use the luminance pass to apply the effect.
Richard Quinn
August 20, 2009 at 7:09 pmHi Adam,
I am a little confused.
Once I have rendered out the white stars having put the texture in the luminance channel of the material.
I have then enabled Material luminance in the multipass render settings and rendered it out.
What do I do with the render to then apply the post effect? Are you talking about going into after effects or can it still be done in C4D?
Sorry for my lack of understanding.
Cheers,
Rich
Adam Trachtenberg
August 21, 2009 at 4:16 amYes, I’m talking about using it as a luma matte in AE. I thought that was what you were trying to achieve?
Richard Quinn
August 21, 2009 at 6:34 amHi Adam,
My aim was to add a Cinema 4D post effect such as “highlight” to my stars on my hat. The stars are on a material though. I know you can’t add an object buffer to a material but wondered if there was work around within C4D.
Cheers,
Rich
