Activity Forums Adobe After Effects Composition settings
  • Composition settings
    Posted by Olly Lawer on March 15, 2012 at 1:40 pm
    We’re creating an animation for a customer that they may want shown on a big screen (half size cinema screen). I was planning on creating a comp 1920×1080.
    Will this be high enough quality do you think?
    Is this the best method of going about it?
    Kind regards,
    Olly Lawer
    Olly Lawer replied 14 years, 5 months ago 3 Members · 5 Replies
  • John Cuevas
    March 15, 2012 at 2:17 pm
    I’ve created 1920×1080 for theatres and it looked fine.
    That being said, call the client and ask who/where this is going to be delivered to and if he can get the exact specs required. That’s your best and easiest option that will save you the most headaches down the road.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Todd Kopriva
    March 15, 2012 at 2:19 pm
    As John says, getting exact specifications from the client is a good idea. Rather than asking about the screen, be sure to ask about what the projection system uses/requires.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Olly Lawer
    March 15, 2012 at 2:21 pm
    Thank you!
    So what other questions do I need to ask / consider apart from resolution?
    And what impact (what settings do I need to adjust) in light of their feedback?
    Olly Lawer
  • Todd Kopriva
    March 15, 2012 at 2:48 pm
    There’s a great article here on the COW about this:
    https://library.creativecow.net/articles/rabinowitz_aharon/delivery.php
    Here is an article in After Effects Help about how to plan your project with client specifications in mind.
    You’ll be making changes in composition settings and output module settings for most of these specifications—and maybe project settings if you decide to use color management to ensure that you’re delivering movies in the right color space.
  • Olly Lawer
    March 16, 2012 at 6:22 pm
    Great! Thanks for your replies. Very useful links and info!
    Olly Lawer
