Activity › Forums › Adobe After Effects › Composition & Preset settings
  • Composition & Preset settings
    Posted by Cecilia Ruiz-smith on March 21, 2011 at 3:08 pm
    I apologize for my question but I’m a real newbie: I’m creating a very short piece that will be burned to a DVD and then shown on an LG 32LG40 HDTV 720 HD Resolution LCD tv Monitor. My question is which preset would be the most appropriate and will deliver a clean sharp image for this particular device? Also, I’m not sure what to select in the pixel aspect ratio box: square or rectangle pixels?
    What’s the minimum resolution for a still image before it begins to soften.
    I apologize for my questions and for taking up your time but I work for a non-profit that can’t afford to hire a professional. And since I am a graphic designer/web developer they asked me to put together a very simple 1-2 minute movie with still photographs because they know I have some experience with timeline production using Flash. They don’t realize that AE & Premiere are far more sophisticated and require some knowledge with various output formats. Can someone please advise me? Thank you so very much.
    Cecilia Ruiz-smith replied 15 years, 6 months ago 2 Members · 5 Replies
  • John Cuevas
    March 21, 2011 at 3:36 pm
    Being that you are sending to an HD monitor, you should be working in a 720×480 comp with 1.21 rectangle pixels. When you render your animation the DVD software should recognize the wide screen format and burn you a dvd that will be read correctly by the DVD player.
    As far as it being sent to a 720 monitor, if you are burning a DVD and not a blu-ray, it doesn’t really matter, it will be upscaled by the monitor.
    I find the AE MPEG-2 DVD preset works very well. If you are using encore you should be able to drop that into a timeline, set your end action and be good to go.
    Johnny Cuevas, Editor
  • Cecilia Ruiz-smith
    March 21, 2011 at 3:45 pm
    Thank you so much. I really appreciate your response. I feel better now with this additional information!
    March 21, 2011 at 3:46 pm
    Thank you, Thank you! This is a great help!
  • John Cuevas
    March 21, 2011 at 3:57 pm
    Glad I could help. One other thing, when rendering sent your “Render Settings” to “DV Settings”
    You should be good to go then.
    April 4, 2011 at 5:35 pm
    THANKS AGAIN!
