Activity Forums Avid Media Composer Compositing on MC
  • Compositing on MC
    Posted by Neil Sinclair on August 30, 2018 at 12:45 pm
    What makes MC composite differently when there is an empty track in the composite?
    Image 1 shows a comp on V3 with a luma key and animatte mask
    Image 2 is the same track moved down to V2
    Any insights appreciated?
    Martin Fox replied 8 years ago 3 Members · 2 Replies
  • Glenn Sakatch
    September 1, 2018 at 3:23 pm
    Been a while since doing this in MC, but i would assume you are filling your key with the track above…which in v2, is black.
    Glenn
  • Martin Fox
    September 3, 2018 at 12:44 am
    Is your luma key nested under your ani matte?
    If so I think the lumakey expects to get its input from v1 in the nest , (not the track v1), if you have nothing in the nest on v1 it looks down to layers below. But this logic does not follow unless you have an empty track underneath.
    Did I mention logic?
