Activity Forums Adobe After Effects Compositing mask path strokes?
  • Compositing mask path strokes?
    Posted by Ross Ishikawa on December 12, 2014 at 10:46 pm
    I am trying to animate a ribbon. The ribbon is to be red with black edges. I can make this easily by compositing 2 strokes (a wide black under a slightly narrower red) on a single path in a shape layer.
    However, I would like to make a mask path to do the same thing (so the ribbon can grow across the screen). Is there any way to composite strokes of a mask path?
    Thank you
    John Cuevas replied 11 years, 9 months ago 2 Members · 1 Reply
  • John Cuevas
    December 14, 2014 at 3:21 pm
    You could make a shape layer “grow” by adding a trim paths animator to your shape layer.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
