Activity Forums Maxon Cinema 4D Compositing in Vray 1.082
  • Compositing in Vray 1.082
    Posted by David Wiffen on March 18, 2009 at 4:56 pm
    Hi Everyone,
    I need to composite a fake 3d object into a footage sequence using Vray. It has to be vray as it’s photo realistic.
    This is how I would normally composite using normal C4D advanced render:
    – Apply footage sequence to C4D material
    – Apply this material to a background object and use frontal mapping, I would also apply the material to any shadow catchers required eg. walls and floors
    – I’d then apply a C4D compositing tag to all shadow catchers. In this tag I would turn off ‘seen by rays’ and ‘cast shadows’ and turn on ‘Compositing background’
    This would then give me a composite to take into AE (with shadow, reflection passes etc).
    My question is how do I do this if rendering through Vray? As the compositing tag doesn’t work and materials dont work in the same way.
    Any ideas would be very much appreicated.
    Lars-gunnar Thorell replied 11 years, 8 months ago 2 Members · 1 Reply
  • Lars-gunnar Thorell
    January 28, 2015 at 2:37 am
    Exactly my problem, and since it never got answered, do you have an answer Dave?
