Activity › Forums › Adobe After Effects › Compositing 3D text/objects into a moving shot…
  • Compositing 3D text/objects into a moving shot…
    Posted by Bob James on August 31, 2010 at 2:32 pm
    Hey everyone,
    I have a question regarding specific footage I have shot:
    https://vimeo.com/13846546
    password: ski
    Now the steadicam shot I used (I have done something similar for the actual music video) I would like to have 3d text/objects ‘pop-up’ from behind the artists shoulders as he says certain parts of his lyrics.
    I’m assuming I will have to do things like ‘tracking’ and ‘camera solving’ and also probably have to mask the subject to have the 3d objects appear like they are ‘behind’ him…as well as lighting the objects etc etc etc.
    That’s my main problem…I just don’t know AE well enough (albeit I’m quick to learn) and I basically need to know specifically what I need to be doing here to achieve my ideas.
    I’ve seen some basic “how to add 3d text to video” tutorials but they are all for static shots and in this case you can see that’s not the case here.
    Can anyone please provide some workflow insight?
    I’m not looking for an easy way out here but any direction to make this process a bit less error free would be GREATLY appreciated.
    Thanks for any help in advance.
    If I’m not being clear enough about what I’m tryin to do please let me know and I will clarify as best I can.
    Much thanks in advance!
    – B
    Kevin Reiner replied 15 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Walter Soyka
    August 31, 2010 at 3:51 pm
    [Bob James] “Now the steadicam shot I used (I have done something similar for the actual music video) I would like to have 3d text/objects ‘pop-up’ from behind the artists shoulders as he says certain parts of his lyrics. I’m assuming I will have to do things like ‘tracking’ and ‘camera solving’ and also probably have to mask the subject to have the 3d objects appear like they are ‘behind’ him…as well as lighting the objects etc etc etc.”
    That is exactly right. You’ll need a 3D tracker like SynthEyes or PFhoe.
    [Bob James] “That’s my main problem…I just don’t know AE well enough (albeit I’m quick to learn) and I basically need to know specifically what I need to be doing here to achieve my ideas.”
    I’ve found After Effects to be both deep and wide. I think it’s very difficult to get any production done — or even to get any deep knowledge in one particular aspect of AE — without first getting a wide understanding of the app. If you’re relatively new to After Effects, check out Todd Kopriva’s blog post Getting started with After Effects.
    Walter Soyka
  • Bob James
    August 31, 2010 at 5:21 pm
    Thanks Walter!
    I am not quite a total ‘n00b’ at AE but in this instance I don’t want to have to re-do everything again due to my overlooking a process or going about things in the wrong order of importance.
    Can you perhaps be more specific as to in your opinion what order to go about things in AE to get the results I am looking for?
    Motion tracking first? etc?
    Any further help you can provide would be greatly appreciated.
    – B
  • Chris Wright
    August 31, 2010 at 5:29 pm
    you don’t need to worry too much, syntheyes is incredibly easy to use, has automatic modes to solve camera tracking, remove bad data, and fix lens distortion, plus the website has tons of tutorials that cover everything you can imagine. did I mention the software is super inexpensive?
    https://technicolorsoftware.hostzi.com/
  • Walter Soyka
    August 31, 2010 at 5:43 pm
    I think you’re already on the right track. You want to track and solve first, so that you can get 3D camera data in AE to begin positioning your elements.
    Keep in mind, though, that AE is really 2.5D. If you want to work with true 3D objects, you’ll be better off in a real 3D app.
    Maybe someone else can comment on a good workflow for the roto portion?
    Walter Soyka
  • Bob James
    August 31, 2010 at 5:44 pm
    Seems like Syntheyes is the way to go!
    Thanks alot guys, I will give it a go and see how far I get with it tonight.
    – B
  • Tudor “ted” jelescu
    August 31, 2010 at 7:21 pm
    Once you have the tracking done, here’s a few suggestions (with some tutorial links tha tmay give you ideas) of what you can use to generate 3d text/objects in AE:
    Zaxwerks Pro Animator,Invigorator
    https://library.creativecow.net/tutorials/zaxwerks
    Zaxwerks Serpentine,
    https://library.creativecow.net/articles/stern_eran/autumn_movies.php
    Trapcode Particular,
    https://maltaannon.com/articles/after-effects/growing-3d-vines/
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
    Bucharest, Romania
  • Kevin Reiner
    November 23, 2010 at 6:15 pm
    Hey Bob,
    I’m working on a similar project. I would love to hear a recap of the project. Did you end up using Syntheyes, and if so, were you happy with it? I thought the video you shot looked great and I look forward to seeing the final comp.
    Kevin
    System Setup (for a more detailed list, see my profile)
    HARDWARE
    Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
    9GB Memory
    Two 16x SuperDrives
    Dual-channel 2Gb Fibre Channel PCI Express card
    Apple Cinema HD Display (23″ flat panel)
    ATI Radeon X1900 XT Graphics Card
    AJA Kona LHe SD/HD capture card
    Apple Xserve Raid 5.6TB
    SOFTWARE
    Mac OS X 10.4.11
    Final Cut Pro Studio 2
    After Effects CS3
    Photoshop CS3
    Illustrator CS3
    Boris Continuum 5
    Sapphire Plug Ins
    Roxio Toast
    Digital Anarchy Anarchist Suite
    ParticleIllusion 3.0
    Trapcode
    Zaxwerks
