Activity Forums DaVinci Resolve composite two shots together
  • composite two shots together
    Posted by Phillip Choe on July 11, 2011 at 7:40 am
    does anyone know how to composite a green screen (foreground) and background shot together and color graded in context?
    I know on the baselight you can put the foreground on layer 1 and background on layer 2 and then grade each individual shot by keying the green screen, and play the action of both shots combined.
    i know warren eagles showed us to composite a shot against a still but would it work in version 8 with both moving images?
    Phillip Choe replied 15 years, 1 month ago 2 Members · 2 Replies
  • Rohit Gupta
    July 11, 2011 at 11:58 am
    You just use a node on layer 2 to key the green screen. Then right click to get an alpha output, and then feed the alpha from this node to the alpha output. You might need to invert the key.
  • Phillip Choe
    July 12, 2011 at 6:15 am
    awesome =)
    i inverted the key and linked the background into the key and graded them both independent in context.
    thanks Rohit
