Activity Forums Adobe After Effects composit rendered out files
  • composit rendered out files
    Posted by Soyeon Park on July 5, 2006 at 7:40 pm
    I rendered out this animation in several different machines.
    When I put all the files together and make a movie out of it, there are flickering.
    Is there any way to solve this problem? Anyone had the same problem before?
    Soyeon Park replied 20 years, 1 month ago 2 Members · 3 Replies
  • Al
    July 6, 2006 at 9:53 am
    what are you rendering out as? try something different, like quicktime mpeg A
  • Soyeon Park
    July 6, 2006 at 3:36 pm
    I’ll try it. I rendered it out Quicktime. When I composit the files that I rendered in one machine, it was fine.
    It is supposely fine compositing with files that rendered out different places..
  • Soyeon Park
    July 8, 2006 at 5:46 pm
    I’m using AE 6.5 and it didn’t have choice of the file that you mentioned..
    I have studio max file and render it out as single frames (targa) and put together in After Effects.
    This is the thing.
    I rendered out one file in one machine and
    I rendered the file in different machines and used the same process of compositing.
    One didn’t have any flickering and ran smoothly and the other one had the same numbers of flickering that the number of machines that I used.
    The result of my thinking is
    if you render file in different machines, it will have some kind of gaps in between that human eye can’t see. Therefore, there is flickering.
    I’m willing to try different way to doing things. Let me know if you have any other idea because it’s supposely work!
