composer screen not on startup monitor
Running composer 5.5 demo on my Mac Pro 1,1 with dual monitors hooked up to a Radeon 5770. For some reason MC wants to run on the secondary monitor. I can rearrange the layout, but hitting home moves the source/record to the other screen. How do I get it to default to the other monitor, and not switch over when I press home cmd+, ?
Also, in the old MC 8000 days when I learned composer (before FCP), there was a command to make the sequence window full height, and lose the source/record windows. Leaving just the source/record scrub bars at the top. Great for audio mixing. Is that still around?
