Activity › Forums › Apple Final Cut Pro Legacy › component>intensity card>jvc monitor
  • component>intensity card>jvc monitor
    Posted by Tielman Dewaele on February 25, 2008 at 5:44 pm
    Hey,
    I got a JVC Tm-H150CG Sd monitor that i want to connect to my intensity pro card.
    I got a input card(sdi, component, video input)
    I can only input with component, witch is fine.
    I got the cables.
    But where oh where do i need to connect the cables.
    I connected the red, green, bleu to inputs. and same with the component thingy cable from my intensity pro card.
    In final cut pro, i put my easy setup to Intensity PAl DV.
    But i got no signal at all.
    I restarted final cut pro several times.
    Set to all frames, refresh etc…
    if someone has this monitor or had several problems with connecting a monitor to the intensity pro card, please help me on this.
    Using Fcp 6.1
    Mac Pro, 3 gigs Ram
    T
    Walter Biscardi replied 18 years, 7 months ago 3 Members · 4 Replies
