Activity Forums Apple Final Cut Pro Legacy component monitoring through Sony HVR-M25U deck
  • component monitoring through Sony HVR-M25U deck
    Posted by Peter Carroll on March 6, 2007 at 12:04 pm
    I just bought a Sony HVR-M25U HDV deck. I am editing with Final Cut Pro 5 on a Mac Pro 2.66. The deck works very well except that I can’t seem to monitor from FCP through the deck
    Logan227 replied 18 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    March 6, 2007 at 3:20 pm
    #25 HDV external Monitor Viewing
    Shane’s Stock Answer #25 – HDV external Monitor Viewing
    To view HDV on an external monitor you are going to need to purchase a capture card, like the ones Decklink or AJA offer. They will both play out HDV in real time. The catch is that you cannot view this on a regular TV or NTSC monitor. Since this is HD, an HD monitor will be needed.
    HDV cannot be played out of FCP via Firewire because it’s Long GOP structure is too taxing on your processors to spare the system resources needed to drive an external monitor.
    The best option you have is the Matrox MXO…$1000.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Logan227
    November 9, 2007 at 3:47 pm
    Pete,
    I have this same problem. I am using the hvr-m25u with component output to a panasonic bt-lh2600w. Tape playback from the deck through the component connection displays fine on the monitor, so do color bars when they are generated by the deck. The issue is with a pass through signal and unlike what the last reply to your post said it has nothing to do with hdv output or hd anything. In my case the pass through works fine when I use an s-video connection like you mentioned, however the problem arises when I use component output with the firewire input even with an sd signal.
    I spoke with sony’s pro support guys and they seem to think that the issue is aggregate instability in the signal by using firewire and component. I asked them if this was a hardware malfunction and they said no; that they do not guarantee pass through playback on these decks, only recording and playback of a recording. I was pretty pissed I have a 5000 dollar deck that can’t properly pass a signal through but in the end they are right and I am at a stand still with this issue.
    Have you been able to make any progress with the issue?
