Activity › Forums › Adobe After Effects › Complicated mask animation
  • Complicated mask animation
    Posted by Tamir. Azoulay on December 25, 2013 at 1:58 pm
    Hello everybody.
    I’m having Problems to make shape animation to mask.
    as you can see in the photo i have this track thet i need to animat from right to laft,
    the small green line’s on the top need to move in the shape of the track.
    I tried to key fame the mask of one part, but no success to make it perfect.
    perfect is Important in this project 🙂
    someone have effective solution to me.
    Thanks for any help
    Tamir
    Tamir. Azoulay replied 12 years, 9 months ago 2 Members · 3 Replies
  • John Cuevas
    December 25, 2013 at 4:56 pm
    Using a shape layer, I made a rounded shape following the path, then created dashes inside the stroke parameter. I added a find edges effect to “stroke” it and then offset the entire animation so that it would rotate around. One issue I had was that when the dashes would go around the corner they would merge together, I was able to fix this by adding a 2nd Dash and Gap, but they only worked when both “Gaps” were 10. I’m not sure why as I don’t use shape layers that often. If you choose to pursue this as a solution, and you need to make changes, perhaps someone else will be able to help you out.
    Here’s the project I came up with, hopefully it will give you a decent starting point for your animation: 6933_dashesfolder.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Tamir. Azoulay
    December 25, 2013 at 8:15 pm
    Hi John
    Thank you vary mach!!
    this is more that i expect to achieve here.
    your animation is excellent to my needs and i think ill use it.
    I’m learning more abut the shape layer now and its grate tool.
    Thanks agin.
    Tamir
  • Tamir. Azoulay
    December 25, 2013 at 9:20 pm
    Hi John
    tanks agin
