Activity Forums Maxon Cinema 4D Complicated cutaway with transparency
  • Complicated cutaway with transparency
    Posted by Andy Baumgartner on September 20, 2016 at 7:26 pm
    Hi, I am trying to create a complicated cutaway animation where the boole is tool slow to practically work with.
    I believe there is a technique for cutaways using materials and transparency instead of the boole, but I can’t seem to find any articles about it. This tutorial accomplishes a similar effect, just using a gradient instead of 3D geometry.
    Does anyone who frequently does cutaways know how to accomplish this? Or know of other tools with better performance than boole?
    -Andy
    Andy Baumgartner replied 6 years, 9 months ago 2 Members · 4 Replies
  • Brian Jones
    September 21, 2016 at 2:42 am
    there was a plugin called rBoole which does booles by transparency. It stopped working in the Standard renderer a couple versions ago but was still working in Physical in R17 (and after a quick test) appears to be working in R18 as well. I don’t know if it’s stable or not but it was in R17.
  • Andy Baumgartner
    September 28, 2016 at 5:44 pm
    Awesome, thanks Brian! I’ll check it out.
  • Andy Baumgartner
    September 29, 2016 at 12:19 am
    Hi Brian, I wasn’t able to find anywhere to download or purchase rBoole. Could you possibly send me the files?
  • Andy Baumgartner
    December 20, 2019 at 4:24 am
    I ended up finding a partial solution by deselecting the “high quality” option. Reducing the number of polygons as much as possible when exporting into C4D also helps.
