Activity Forums Adobe After Effects Complex vector animation problem
  • Complex vector animation problem
    Posted by Jesse Heinilä on August 7, 2019 at 4:42 pm
    Hi! I’m having real hard time figuring this problem out and can’t seam to find any tutorial anywhere related to this. I have this vector file seen here and I would like to animate these small triangles changing size in random waves. This would work only in small scale using the sampleimage expression on a control layer that has an evolving turbulence. But since all the particles/shapes have to be on separate layers using this technique, I can’t use this vector texture since it has over 6000 triangles.
    Someone suggested to use Trapcode Form with a custom sprite but didn’t elaborate more on it and since I’v got it installed but new with it, I thought you gurus could help me figure this out. Alternatively if you have anyway of achieving this effect, I’d be super grateful. Thank you!
    Jesse Heinilä replied 7 years, 1 month ago 2 Members · 2 Replies
