Activity Forums Audio Complex shoot comming up… need help.
  • Complex shoot comming up… need help.
    Posted by Harry Pallenberg on January 10, 2006 at 5:43 pm
    Ok – I’m working on a LOW BUDGET doc film. We’ve basically spent all the porduction $ we had.. now there is 1 more shoot! And it’s a hard one. There will be about 15-20 ladies at a cocktail party. At least 10 of them are critical to the show… maybe more.
    There will be 3 or 4 cameras (Sony HDV cameras all with 2 XLR) to cover the event (1 might be stationary in the extra bedroom as a ‘confessional’ booth – so sound is easy for that one). I want to lav all the main ladies – I want to let them be free, I REALLY want them to forget we are there… ie if 2 of the sneak away to have a smoke the camera will not follow them, just zoom – hopefully they will forget the lavs and let it rip!
    So if I have 3 cams I can hook up 6 lavs that way… what is the best / cheapest option to get the other ladies laved? Can I get a TimeCode sync to the cameras? That would be nice! Seems like I shoudl maybe bite the bullet and hire a pro sound guy… any ideas how much a guy with 15 wireless lavs get for a day rate in Vegas?
    I’m sure I’m leaving stuff out… will post more if/when I think of it, till then thanks in advance for any help.
    Harry.
    Forum Cowmunity Leader: OSX
    Forum Cowmunity Leader: Indie & Doc
    Dual 1.8 G5 ** 1GB ** 10.4.1
    David Jones replied 20 years, 8 months ago 2 Members · 1 Reply
  • David Jones
    January 11, 2006 at 2:34 pm
    Well Harry, this is another fine mess you have got yourself into! 🙂
    The 6 mics into the 3 cameras would be hell to edit unless they were to only follow the ladies with their mics.
    Might I suggest something along these lines since budget is an issue, yet the audio is extremely important for a shoot like this….
    Sound Guy with computer as main recorder, using multi-input audio interface.
    Something like a Mac G4 with a MOTU 828mkII would do for this budget project.
    Recording software could be Gallery’s Metacorder, or again because of the budget, BoomRecorder.
    This would give you a clean iso of each mic.
    I would also probable use a set mic for room tone and overall ambiance, along the lines of an Oktava mk012 again because of budget.
    A mixed feed could then be sent via radio back to each camera if budget allows, and if not use the on camera mics to give you a form of sound to sync to.
    The tricky part comes when it’s time to sync three cameras and audio, if your budget won’t allow for timecode and smart slate.
    I don’t know how long the event is, but if you were to slate once at the beginning and roll non-stop then your sync in post should be fairly painless.
    Good Luck!
