Activity › Forums › Adobe After Effects › Complex scene cleanup, need advice
  • Complex scene cleanup, need advice
    Posted by Constantin Kormann on January 21, 2017 at 1:55 am
    I’m recently working on some footage we shot in estonia last year.
    The Lighting guys kind of messed up and I have a lot of cables to remove.
    In a lot of the scenes I can work with A) simply freezing parts of the image, tracking them and then rotoscoping or B) Clonestamps thousands of them.
    But A) Is tedious and looks ridiculous when closer up/in focus and B) is even more tedious, but even starts flickering since I can’t repair the frames all the same way.
    This one scene really kills me right now, I have no idea how to get rid of the cable.
    Can you guys provide me with ways i could tackle this? Or tackle complex repairs in general?
    Thanks in advance!
    Constantin Kormann replied 9 years, 8 months ago 4 Members · 6 Replies
  • Mohammed Anis
    January 21, 2017 at 5:00 am
    Hi Constantin,
    I have given this scene good repitition of replays and the fact that I’m still unsure if I”m seeing the cable you’re talking about or that the cable might be some long range TV extension for the house owner in the story should indicate that this detail can be overlooked.
    You obviously know what happens after this snippet, so its upto you. However, some perfections are worth overlooking.
    Might I ask if you’re using Mohca to do the tracking job?
  • Tero Ahlfors
    January 21, 2017 at 9:00 am
    [Dave LaRonde] “I have looked at that clip five times and I don’t even SEE any cables.”
    Lower left of the door going next to the stairs. That said I had a hard time seeing them too.
    You’ll need:
    -A really good removal artist
    or
    -Mocha Pro that has the remove module in it and a bunch of clean plates from different points of the clip
  • Adam Lewen
    January 22, 2017 at 10:35 am
    Hi Constantin.
    I would take a “best resolution” 1 frame (PNG) from pretty much the middle of the clip (where the cable is seen at its glory ☺
    take it to photoshop – > clean/clear the cable there (stamp tool) .
    Go back to AE to the same frame you exported -> import the cleanup PSD from photoshop put the clean layer ontop of your shot.
    I would use Mocha for AE to track the cable, paste the tracking information (transform data with prespective) to a null and from that good clean frame you have, parent the clean layer to that null.
    The handrail probably will need to be copied ontop of everything and masked so it would “cover” the cleanup.
    I did a 5 minute mockup to illustrate what im talking about, with 10 more minutes it will look much better ???? but you can understand from seeing the mockup. it’s really not perfect and could use a bit of manual positioning toward the end, but hey! no cable
    Hope it helps!
    clenaup in photoshop and tracking back…
    cheers Adam
    https://www.youtube.com/watch?v=t2j3SZabRgM&feature=youtu.be
  • Constantin Kormann
    January 22, 2017 at 10:54 am
    Thank you Adam! I completely forgot about Mocha, it seems like a much better solution than attempting a manual track with the integrated plugin.
    Im gonna give that a shot.
    To answer the other comments: The film takes place in a 1920s Finnland, so any cables really stick out.
  • Adam Lewen
    January 22, 2017 at 10:57 am
    So yes I believe Mocha + clean plate + a bit of manual adjustments will give you an unnoticeable solution!
    Good luck!
    January 22, 2017 at 5:10 pm
    This took me way too long, I really need to practice this more.
    I’m still not 100% satisfied but I need to turn this in.
    Thanks for the help everyone, here is the result:
