Activity Forums Adobe After Effects Expressions Completion % slider control with Delay
  • Completion % slider control with Delay
    Posted by Ilya Sire on January 21, 2021 at 7:23 pm
    I have 3 layers that have a linear expression on rotation and im create a slider A 0 to 100 as completion percent.
    A = effect("Completion")("Slider");
    index = 0 // layer 1
    totalLayer = 3
    offset = 1.5*index*thisComp.frameDuration;
    linear(A,(100/totalLayer)*index,(100/totalLayer)*(index+1),0,90);
    index = 1 // layer 2
    totalLayer = 3
    index = 2 // layer 3
    totalLayer = 3
    I’m not sure this proper way to this but worked, it starts one after another.
    The question is, how can I make it time offset (to faster or delay), that calculated in the slider Completion percent?
    Thank you
    Filip Vandueren replied 5 years, 8 months ago 2 Members · 1 Reply
  • Filip Vandueren
    January 22, 2021 at 1:11 pm
    Be aware that “index” is a reserved keyword in expressions and shouldn’be used as a variable name.
    I’m not entirely sure what your question is, but maybe something like this:
    A = thisComp.layer(1).effect("Completion")("Slider");
    i=index-1;
    totalLayer = 3;
    overlap = 2;
    totalLayer+=overlap;
    linear(A,(100/totalLayer)*i,(100/totalLayer)*(i+overlap),0,90);
    At overlap-values between 0 and 1, there will be a pause between each next turn.
    Overlap==1 will be no overlap.
    Overlap > 1 will give more and more overlap
