Activity Forums Maxon Cinema 4D Comping into Live Action
  • Comping into Live Action
    Posted by Rob Hindley on September 21, 2005 at 7:39 am
    I am ready to render my character for comping into live action in after effects. What is the best way to proceed?
    Chris Smith replied 21 years ago 3 Members · 2 Replies
  • Arndt Von koenigsmarck
    September 21, 2005 at 2:25 pm
    It is hard to do this without specialized software such as image or 3D trackers. They analyse the movie and calculate a 3D camera from it. This can be imported to C4D and used to render out your 3D objects. A later compositing of the live action movie with the rendered movie should match perfectly then.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Chris Smith
    September 21, 2005 at 9:15 pm
    In regards to matching the original camera move or render passes and compositing?
    If it’s a dead lock off, or a small bit of hand held long lens work you can match move it using a 2D tracker in a compositor. If you are going to see perspective changes, you need a 3D tracker like SynthEyes to get your C4D cam to match to the real Cam.
    As far as compositing, C4D makes it very easy if you are going to AE, Shake, or Motion. Just read your manual on how to render out multiple passes and generate a project file for one of those apps.
    Chris Smith
    https://www.sugarfilmproduction.com
