Activity Forums Adobe Premiere Pro Compatibility Problem with CS5 and CS6
  • Compatibility Problem with CS5 and CS6
    Posted by Geoffrey Shea on March 5, 2013 at 7:35 pm
    I created a vignette effect in a project in CS5 by adding an inverted circle to a layer, feathering it and scaling it to slightly darken the corners of my image. Worked great!
    I had added some keyframes to the Scale Width to adjust the area that was affected during camera moves. Opening it is CS6 however, some of them have newly added keyframes on the Position and the vignette has moved way over, showing the edge of the effect in the middle of the image.
    I doubt there is a fix for this. So my question is: Can I reinstall CS5 in my Mac so I can continue to use this older project? I was told that they do not co-habitate very well.
    Geoffrey
    Ann Bens replied 13 years, 6 months ago 2 Members · 1 Reply
  • Ann Bens
    March 5, 2013 at 9:54 pm
    General advice is to finish project in same version as started.
    But you can finish the project in CS6, just redo the effect.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
