Activity Forums Adobe Premiere Pro Comparing Master Codecs. UT and DNxHD
  • Comparing Master Codecs. UT and DNxHD
    Posted by Tom Daigon on July 26, 2012 at 5:04 pm
    Now that I’m in PC land I decided to explore alternative codecs. I was interested to see variances in render times and file size.
    I took the “Dancin Footloose” project and exported it first as UT (AVI) then DNxHD (QT). They took about the same time to export (6:30 for an effects heavy 3:09 timeline). The UT file was 7GB and the DNxHD was 3GB. Close inspection revealed no discernible difference.
    Somehow I thought getting away from Quicktime wrapped codecs would speed things up. This was not the case in this test.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
    Tom Daigon replied 14 years, 2 months ago 3 Members · 4 Replies
  • John-michael Seng-wheeler
    July 26, 2012 at 10:18 pm
    I don’t think the 32bit limitation is going to slow down DNxHD encoding all that much. Remember, the only problem with 32bit is the amount of RAM it can access. So as long as it can do the encode efficiently with only 4GB of RAM (which, because the system is 64bit, it can have that 4GB all to itself, unlike a 32bit computer where it would be 4GB for the entire system) then you won’t see a speed reduction. Remember, Premiere is handeling the rendering in a 64bit process, then handing the completed frames to Quicktime to encode into DNxHD.
    If you want to really test this, try exporting the same timeline to H.264 in a Quicktime and H.264 straight. (.mp4)
    H.264 is a much more intense codec, and you can do a direct apples to apples comparison between the Quicktime engine and Adobe’s.
  • Tom Daigon
    July 26, 2012 at 10:51 pm
    Good idea but a moot point. I would never master to h.264. AVCIntra has been also mentioned as an alternative to QT or AVI wrapped codecs by someone who I have great respect for. I will explore that possibility.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Walter Soyka
    July 27, 2012 at 1:53 pm
    [John-Michael Seng-Wheeler] “I don’t think the 32bit limitation is going to slow down DNxHD encoding all that much. Remember, the only problem with 32bit is the amount of RAM it can access. So as long as it can do the encode efficiently with only 4GB of RAM (which, because the system is 64bit, it can have that 4GB all to itself, unlike a 32bit computer where it would be 4GB for the entire system) then you won’t see a speed reduction. Remember, Premiere is handeling the rendering in a 64bit process, then handing the completed frames to Quicktime to encode into DNxHD.”
    That’s where the slow-down comes from. Premiere, a 64-bit process, cannot interface with the 32-bit QuickTime libraries directly. Adobe runs a 32-bit helper application and communicates with it from Pr/Ae via the network stack, using TCP/IP to pass frames and control data back and forth.
    If Premiere Pro’s renderer is synchronous (as I believe Ae’s renderer is), then rendering the next frame cannot begin until the prior frame has been written. This might be worth testing.
    Walter Soyka
  • Tom Daigon
    July 27, 2012 at 4:38 pm
    AVCIntra is not the answer. It does not generate just one file, but separate audio and video with a plethora of folders. And I did not find a readily accessible player for viewing the resulting MXF files. I guess I will stick with DNxHD until something better comes along, despite the slower export.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
