Activity Forums Adobe After Effects Expressions Compare and change Marker color Script question
  • Compare and change Marker color Script question
    Posted by Craig Trayler on March 15, 2023 at 11:15 am
    Hi, is there a way to modify the color of a marker based on two layers having the same marker in the same location but the text inside is different?
    Example. If I had two identical layers with markers at the same points, and inside had the same text content, but later on the second layers markers text content inside some of the markers have changed, is there some kind of script that will compare both layers markers and if the marker text content does not match, then that marker color will be changed to, say RED?
    I know it must be possible with the command:
    myMarker.label = 1; // red
    But the comparison part is beyond me.
    Thanks in advance for any help.
    Craig
    Craig Trayler replied 3 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
