Activity Forums Adobe After Effects comp window distorts (help needed)
  • comp window distorts (help needed)
    Posted by Tom Lee on September 9, 2009 at 3:04 pm
    Hey Guys, Im quite new to after affects so this maybe a really common problem but i have searched high and low accross the net to find a soloution.
    Basically everytime I increase or decrease an effect parameter in after effects my comp window becomes highly distorted so that i cant see the effect the change is having on my comp unless i release the mouse.
    Here is a link to my problem, the top image is before I alter the comp and the bottom two are while I scroll the effects incrementaly. as you can see it is impossible for me to see the effects of the change.
    https://i92.photobucket.com/albums/l29/tom_lee85/aeproblem.jpg
    Hope you can help me.
    Todd Kopriva replied 17 years ago 2 Members · 1 Reply
  • Todd Kopriva
    September 9, 2009 at 4:44 pm
    When you are changing a property value, After Effects has to render the image with the result of the change. Sometimes, this takes a relatively long time. There are different preview modes that you can use to deal with this lag—each of which provides a different way of “keeping up”. Adaptive resolution drops the resolution of the image while you are making your changes. Turning off Live Update, on the other hand, tells After Effects to not even bother trying to keep up with the changes while you are dragging. Hopefully, all will be clear whn you read the preview modes page.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
