Activity › Forums › Adobe After Effects › comp time from selected layer short cut
Posted by Jared Hobbs on April 16, 2010 at 1:14 amIs there a short cut that will change the composition settings timeline to the layer you have selected?
Todd Kopriva replied 16 years, 5 months ago 2 Members · 2 Replies -
Jared Hobbs
April 16, 2010 at 6:38 pmAnyone? I have seen a shortcut key for this before but I don’t remember it.
Todd Kopriva
April 25, 2010 at 8:31 pmThere’s no single shortcut, but this way is relatively fast:
Set work area to duration of selected layers or, if no layers are selected, set work area to composition duration: Ctrl+Alt+B
Then you can use Composition > Trim Comp To Work Area.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
