Activity Forums Adobe After Effects Comp Size for theater screen
  • Comp Size for theater screen
    Posted by Legend on June 28, 2006 at 5:49 pm
    I am compositing a open title sequence that will be viewd in theaters. In my comp setting window does it matter what size I use. The open will be projected with an lcd projector on to differen screen sizes do I need to do a different comp setting to macth the screen size.
    Steve Roberts replied 20 years, 3 months ago 4 Members · 3 Replies
  • Walter Biscardi
    June 28, 2006 at 6:07 pm
    You title sequence should match the frame size of the film.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Steve Bradbury
    June 29, 2006 at 2:55 pm
    The size of image on the screen depends on the focal length of the projector lens and the distance of the projector from the screen. You could try to match the comp size to the resolution of the projector, but standard DVDs and video formats are usually acceptable.
  • Steve Roberts
    June 29, 2006 at 3:11 pm
    The issue isn’t the screen size but the delivery medium. DVD? Hard Drive? Film?
    You need to talk to a techie who will be receiving your file. Same as always.
    I’m working on a spot to be projected digitally in the UK. I spoke to the techies over there, and they requested a standard-def PAL widescreen Digibeta tape. I used AE’s PAL widescreen preset for the graphics.
