Activity Forums Adobe After Effects Comp settings
  • Comp settings
    Posted by Josefine Gustavsson on August 20, 2011 at 3:03 pm
    I have an existing animation that I need to adapt to the following specs:
    Aspect ratio: 16:9 anamorphic and needs to be PAL format.
    A full screen image is delivered at 1024 x 576.
    The original comp settings for my animation is 16:9, square pixels. 1280 px x 720 px.
    As far as I understand I need to set up a new comp and import a .mov file of the animation into it. However the anamorphic setting is really confusing. How do I solve this without ending up with a distorted animation?
    Advice would be much appreciated. Thanks!
    Ben G unguren replied 15 years ago 2 Members · 1 Reply
  • Ben G unguren
    August 20, 2011 at 7:45 pm
    AE has presets for things like PAL anamorphic. If you already have a 16:9 video, you should set up the comp using AE presets, drop in your video, then press command+opt+F (ctrl+alt+F on PC) to fit your video to the screen.
    Pal is 720×576. In theory you’d create a 16:9 animation at 1024×576 then squish that horizontally to fit the 1024 into the 720. You will be squishing vertically as well as horizontally, but that shouldn’t matter unless you have fields in your video, but I don’t think you will with a 1280×720 video.
    The only other possible problem is if your video is running at 24fps, as PAL runs at 25fps. Two options here:
    1. Interpret your footage (command+opt+G / ctrl+alt+G) and set the fps to 25fps. Make sure this doesn’t mess up any of your audio, though. Also you should note that this will make your video a little bit shorter….
    2. Just drop your 24 into the 25. Every 24th frame will fill two frames. Depending on the nature of your video, this may or may not disrupt the flow of things.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
