Activity › Forums › Zaxwerks › comp lights
  • comp lights
    Posted by Mike Johnson on May 3, 2007 at 4:15 pm
    For whatever reason, “use comp lights” is not behaving as i would expect it to. I have a simple comp, with 2 invig layers, one “floor” 3d solid, and 4 lights. i selected “use comp lights” in my invig layers. i do notice a difference, so it is accepting the lights. however, when i bring the lights’ intensity down to zero ( i want to fade the lights up) my floor goes black, but my invig layers stays lit. is an opacity animation the only way to do this or am i missing something?
    System 1: G5 2Ghz DP, 1.5 GB RAM, OS 10.3, FCP 4.1, QT 6.4, AE 6.0, 2 TB Xserve RAID through a Vixel 335 Fibre switch, DVCAM SDI a/v and BetaSP Component through AJA IO, NTSC monitor through Videotek VTM100 through IO
    Second System: G4 1Ghz DP, 1 GB RA
    Mike Johnson replied 19 years, 4 months ago 2 Members · 2 Replies
  • Matt Rhodes
    May 3, 2007 at 5:33 pm
    Hi Mike.
    Would you mind sending my your project (.aep file only)?
    I’d be happy to take a look. You may have found a bug.
    Send files to:
    matt@zaxwerks.com
    Thanks a lot.
    Matt Rhodes
    Zaxwerks, Inc.
  • Mike Johnson
    May 3, 2007 at 6:19 pm
    sent
