Activity Forums Adobe After Effects Comp Dimension conversion
  • Comp Dimension conversion
    Posted by Carmen FraserKing on May 13, 2025 at 1:39 pm
    I need to convert a 16:9 landscape project to 9:16 portrait. Methods I’ve tried: Nesting the old comp into a new 9:16 comp, then manually converting all nested comps. Doesn’t really work because positioning and anchor points of the nested comps don’t align with the original animation…. Also tried using the Scale Composition.jsx script but it doesn’t allow separate width and height dimensions….. Can anyone help me understand what the correct method please?
    John Martin
    replied 1 year, 4 months ago
    2 Members · 1 Reply
  • John Martin
    May 13, 2025 at 8:02 pm
    hi! i can solve this for you but your request seems a little all over the place, can you send a screen recording of your issue? (you can use Loom: https://www.loom.com/ or OBS)
    then i will be happy to record a custom video tutorial for you with the cleanest solution! 🙂
