Activity › Forums › Commotion › Commotion 3.11 display problem
  • Commotion 3.11 display problem
    Posted by Paul Nixon on November 30, 2005 at 6:33 pm
    Hi folks,
    I changed my system from an Athlon 2500+ to an A64x2 3800+ and from a Radeon 9800Pro AGP to a Radeon X550 PCIe, and I’m having a real problem with flicker on the Commotion tool boxes/buttons. OS is Win2k. I had some mild flicker in the past with the 9800Pro but nothing like this. Display is set for 1280x1024x32bpp@75Hz. It’s also very unstable now.
    If you need more info, let me know.
    Recommendations?
    Paul Nixon
    Paul Nixon replied 20 years, 10 months ago 2 Members · 4 Replies
  • Matt Silverman
    November 30, 2005 at 8:18 pm
    Since we’re a mac shop, the only fix I ever give for Windows is the same… try going to your QT control panel and switch it to “GDI Safe Mode”. Seems to fix most issues on Windows.
  • Paul Nixon
    November 30, 2005 at 10:28 pm
    I did as you suggested and it is rock solid now. Many, many thanks! Do you know if this has anything to do with, as I recall, some sort of incompatibility with >QT5?
    Paul Nixon
  • Matt Silverman
    November 30, 2005 at 10:40 pm
    It’s just a simple fact that Puffin never had time to iron all of the bugs out of the Windows version, and Pinnacle never bothered updating it.
  • Paul Nixon
    November 30, 2005 at 11:54 pm
    I think Microsoft is in the same boat. 😉
    I can’t complain – I use what I have available.
    Thanks again…
