Activity Forums Apple Final Cut Pro Command Delete and External Media
  • Command Delete and External Media
    Posted by Jim Bachalo on June 23, 2014 at 12:11 pm
    Am I correct in assuming that it is ‘safe’ to use command delete to remove media from your Library, as long as the media is external? By safe I mean, the actual media won’t be deleted, just the alias or reference. And by external, does the media have to be just external to the Library, or on another drive entirely?
    You should follow me on Twitter here. My latest work
    Jeremy Garchow replied 12 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 23, 2014 at 7:08 pm
    [jim bachalo] “Am I correct in assuming that it is ‘safe’ to use command delete to remove media from your Library, as long as the media is external? By safe I mean, the actual media won’t be deleted, just the alias or reference. “
    That’s correct.
    [jim bachalo] “And by external, does the media have to be just external to the Library, or on another drive entirely?”
    External to the Library. The media can be on the same drive.
