Comet Light
Posted by Joao Souza on March 25, 2014 at 8:09 amGuys please help me with an idea.
Imagine a photo of a beauitiful green field, it’s night and a fire comet flies by close to the ground,as it’s on fire and it’s night how could I make it illuminate the area it flies over?Is(are)there a way(s) to do that?
I have some ideas but they all will give me a lot of work so maybe you guys know an easier way to do that.
Thanks.We have so much time and so little to do! / Willy Wonka
Dave Affholter replied 12 years, 5 months ago 4 Members · 17 Replies -
Graham Bernard
March 25, 2014 at 8:52 amFirst thoughts would be:
1/- Start with a Green field captured in daylight.
2/- Use any of the Luminance FXs and Chroma to desaturation and restrict their effect to the outside of a Mask of the shape of the descending Comet.
3/- Track and Sync the Mask across the Green field.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
John Bolton
March 25, 2014 at 10:31 amJust a quick and dirty 5 minute attempt, but is it something like this you are explaining. Obviously needs more time to make a proper version but it is using the technique as described by Graham
https://www.dropbox.com/s/i7m58lp68fj2pfe/first%20comet.wmv
Joao Souza
March 25, 2014 at 10:39 amThanks guys but like I said, field pic is at night, there’s no day version.
But I understand you guys point, is there a plugin that could illuminate that night pic wherever I want?
This way I could make that plugin illumination follow commet 😉We have so much time and so little to do! / Willy Wonka
Graham Bernard
March 25, 2014 at 10:45 amYou have a dark field, then maybe just a tiny lift in Luma and Chroma will do it. All the Mask stuff would be the same. Wanna give us a ScreenGrab//Still of the Field.
G
Graham Bernard
March 25, 2014 at 11:18 am[Joao Souza] “is there a plugin that could illuminate that night pic wherever I want?”
Yes. And to follow use the Mask in Pan Crop.
Bye!
G
Joao Souza
March 25, 2014 at 11:36 amBut…………………what plugin?
John Bolton
March 25, 2014 at 12:36 pmLike this? Or maybe I don’t understand…..
https://www.dropbox.com/s/gndm72m7wrtpbu2/night%20comet.wmv
Joao Souza
March 25, 2014 at 3:43 pmYeah but how could I do that without a day version of the field?
Probably impossible because no plugin could illuminate something that doesn’t exist LOL
Ok let’s assume I have both night and day versions, do I have to “draw” comet shape with mask?
If yes it means its borders will be hard meaning not like light but like a wall, can I make softer edges letting “light” scapes a little like a blur effect and not ending so hard?We have so much time and so little to do! / Willy Wonka
John Bolton
March 25, 2014 at 5:47 pmUmm so you want a night scene without any Green field….? You said ” Imagine a photo of a beauitiful green field, it’s night and a fire comet flies by close to the ground, as it’s on fire and it’s night how could I make it illuminate the area it flies over” so do I think you want green grass but not to see it as it is night time and only show when the comet goes over ( as in the quick demo https://www.dropbox.com/s/gndm72m7wrtpbu2/night%20comet.wmv) Maybe you can do a PIC file to show what you need……. In the Demo the Green field is dark unless lit up by the comet…Maybe others on here can enlighten the question a bit as clearly I miss understand you..
Joao Souza
March 25, 2014 at 6:24 pmYou did it right,I said “imagine a green field AT NIGHT, or a beach whatever, it’s night so it’s dark maybe with a full blue moon, a comet flies by and its light illuminates where it passes, illuminate doesn’t mean whatever is below will become day.Your video is right 😉
