Dave Affholter
March 25, 2014 at 9:08 pmAnother option for lighting your scene with the movement of the comet…Add FX Sony Bump Map with the spotlight setting > Set bump height to 0 and use Location>Destination to track the movement of the comet and light the scene as it flies past. Use the clock button to “animate” the motion with keyframes as it moves past.
To create the comet, instead of drawing a comet shape, you may consider using a generated media (keyframe x movement) along with linear blur to create a particle trail behind a firey comet. I recommend trying the cloud cover generated media as a start and potentially add some starry sky (for highlight particles) as well. The key is to create the movement like you would see with particles coming off of a comet. I have made several comets over the years and have found this to be a valid option. -
Joao Souza
March 25, 2014 at 9:57 pmThanks Dave I’ll try that.
I assume I should add that sony plugin to green field pic(or to whatever pic I use), right?
I create comets with PI 😉We have so much time and so little to do! / Willy Wonka
Dave Affholter
March 26, 2014 at 12:04 amYes, the bump map should apply to the background pic. I am unfamiliar with PI. what is it?
Joao Souza
March 26, 2014 at 12:30 amhttps://www.youtube.com/watch?v=gZZaL01zQPc
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Dave Affholter
March 26, 2014 at 12:38 amVery nice. just a heads up, I created a comet as a 3D animation major in college and the science profs informed me that comets actually have 2 tails. One is a fiery particle trail following the movement of the comet and the other is an icy blue tail (vaporized by the sun’s radiation) beaming away from the sun as it passes.
Joao Souza
March 26, 2014 at 12:54 amYep, the universe is amazing but some waste time loving gold, diamonds and ferraris 😉
I love living things and my biggest love is for nature, it’s so amazing, sadly we took ourselves out of it so now the majority act/think they’re not part of nature and that’s why we’re destroying everything.
Thank God I’m not in that path, life to me is so precious and that’s why I don’t kill even a cockroach and this planet is………….FREAKIN’ AMAZING!We have so much time and so little to do! / Willy Wonka
