Activity Forums Adobe After Effects Expressions Combining two expressions
  • Combining two expressions
    Posted by Tom Szymanski on August 3, 2020 at 5:54 pm
    I feel like this is a really basic question, but for some reason I can’t quite get it to work. How do I combine these two separate expressions?
    The top ones is for having the source text’s content generated by the name of the comp:
    compName = thisComp.name;
    and this one draws the text’s style (primarily font) from a different layer:
    var parentStyle = thisComp.layer(“TEXT 3”).text.sourceText.style;
    The intent is to have the style pulled from a composition that acts as a control panel for the whole project, so all fo the other compositions will change when I change the control comp. But, additionally, to have the comp names generate the text itself so when I export stills the file names will match what the text says with only having to type it out. (I have to do like 2 hundred of these per project).
    I’m running CC 2020 on a Mac.
    Tom
    var parentStyle = thisComp.layer("TEXT 3").text.sourceText.style;
    Tom Szymanski replied 6 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 3, 2020 at 6:25 pm
    Try it this way:
    parentStyle.setText(thisComp.name)
    Dan
  • Tom Szymanski
    August 6, 2020 at 3:36 am
    Thank you Dan! I appreciate the help!
