Activity › Forums › Apple Final Cut Pro Legacy › combining source material
  • combining source material
    Posted by Stefiny on June 22, 2006 at 4:36 pm
    I have imported three different source materials into FCP 5. Uncompressed 8 bit 4:22, DVDVCPRO-NTSC 16 bit integer, and 32 bit Floating Point. It obviously have two different looks when I export. I don’t know how to give a uniform look and sound for the sequence. How do I do this? Also the Uncompressed 8 bit gives me trouble when I try to export a quicktime movie. I tried Quicktime conversion using the Uncompressed 8 bit 4:2:2 (which worked) but I want to be sure that the whole sequence exports correctly for the final export. What do I do?
    One last question: My keyboard went blank for some reason, i.e. not keyboard shortcuts worked. I went to default… nothing there. So I manually put some commands back. Fine. Is there an easier way to take care of this?
    Stefiny replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
