Activity › Forums › Apple Final Cut Pro Legacy › combining source material
  • combining source material
    Posted by Stefiny on June 22, 2006 at 5:43 pm
    I have imported three different source materials into FCP 5. Uncompressed 8 bit 4:22, DVDVCPRO-NTSC 16 bit integer, and 32 bit Floating Point. It obviously have two different looks when I export. I don’t know how to give a uniform look and sound for the sequence. How do I do this? Also the Uncompressed 8 bit gives me trouble when I try to export a quicktime movie. I tried Quicktime conversion using the Uncompressed 8 bit 4:2:2 (which worked) but I want to be sure that the whole sequence exports correctly. What do I do?
    One last question: My keyboard went blank when trying to use shortcuts. I went to default… nothing there. So I manually put some commands back. Fine. Is there an easier way to take care of this?
    Stefiny replied 20 years, 3 months ago 3 Members · 4 Replies
  • Tom Meegan
    June 23, 2006 at 7:14 am
    Hi Stefiny,
    Your best bet for matching source material once it is in FCP is probably to use the Color Correcter 3-Way filter (Effects > Video Filters > Color Correction > Color Corrector 3-Way.)
    Matching footage is part art and part science
  • Stefiny
    June 29, 2006 at 6:38 pm
    My problem is that I actually imported some clips with a 4:3 ratio. So now my footage is mixed. I would like it to all to be 4:3. Can I change the 16:9 to 4:3. How would you do it?
  • David Battistella
    June 29, 2006 at 7:38 pm
    You need to place the footage in the 4×3 sequence and then you will see the black bars at the top and bottom.
    In order to fit the screen aspect you need to Blow Up the 16×9 by about 120% to loose the letterbox and then of course you will loose the sides of your shots too.
    David
    Peace and Love 🙂
  • Stefiny
    June 30, 2006 at 4:53 am
    Could I export them as a qt conversion and then pull them back into the project?
