Activity › Forums › Adobe After Effects › Combining several paths from Illustrator to one AE mask
  • Keith Mcgregor
    July 26, 2010 at 7:14 pm
    Sorry, it really doesn’t work that way, when you select all and copy, then tab over to AE and paste, it brings all the paths and makes them separate because it sees all the paths, some are intersecting and some are probably not closed. You’d have to make it one path in Illus and then it will see one path in AE. Is there anyway you can make it one path?
    -Keith
    Reality? What did you make it?
