Activity › Forums › Adobe Illustrator › combining path points – non end point
  • combining path points – non end point
    Posted by Nathan Quattrini on March 16, 2007 at 6:08 pm
    I have some paths that I need to combine. Not all points where they visually intersect (they are separate paths but have points in the same spots) are end points. So one end point of Path 1 is in the same spot as the middle point of the curve of Path 2. How can I join these two points and make the path one path? I need to for importing into AE, it needs to be only one path the do what I need. Thanks.
    Vincent Rosati replied 19 years, 6 months ago 2 Members · 2 Replies
  • Nathan Quattrini
    March 16, 2007 at 6:28 pm
    oops…forgot to mention its Illustrator CS 2
  • Vincent Rosati
    March 19, 2007 at 12:28 am
    I think you need to combine all of the paths into a compound path. Select all of the paths and press Ctrl+8 (Object/Compound Path/Make).
