Activity Forums Adobe After Effects Combining images to create postcard
  • Combining images to create postcard
    Posted by David Distinti on February 5, 2009 at 12:39 pm
    I have two images that represent the front and back of a postcard. How do I attach them together so I can rotate them in 3D space.
    Also…Which version of AE can I import HDV clips into. Thanks!
    I have AE 6.5 professional for the PC.
    Best Regards,
    Dave
    David Distinti replied 17 years, 7 months ago 2 Members · 2 Replies
  • Jon Geddes
    February 5, 2009 at 6:03 pm
    Or an even better way to do it…
    https://www.motionscript.com/design-guide/invisible-facing-away.html
    Use the expression for the opacity for each side of the postcard:
    if (toCompVec([0, 0, 1])[2] > 0 ) value else 0
    import each one into the comp, rotate the backside 180 degrees on the y-axis, apply the expression to the opacity on each layer, create null object and parent each layer to it. Using the expression method, you wont have any issues if the postcard is far away from the camera, or if you use depth of field, or if the layers have motion blur applied to them. Good luck.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • David Distinti
    February 6, 2009 at 10:58 am
    Thanks for the help guys!
    Dave
