Activity Forums Adobe After Effects Expressions Combining expressions on same layer
  • Combining expressions on same layer
    Posted by Sean Platt on October 16, 2015 at 5:05 pm
    Hi. I am new at learning expressions and trying to figure out how to combine to expressions on same layer. Essentially, I am trying to bounce an object into the frame from off stage and then begin to wiggle once it has finished the bounce. Any help would be greatly appreciated.
    <b>The first expression I am using is:</b>
    amp = .03;
    freq = 3.0;
    decay = 5.0;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n--;
    if (n == 0){ t = 0;
    }else{
    t = time - key(n).time;
    if (n > 0 && t &lt; 1){
    v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{value}
    <b>The second expression I want to add is:</b>
    wiggle(1,9)
    Sean Platt replied 10 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 16, 2015 at 5:30 pm
    I would put the wiggle at the top of the expression (saving the actual wiggle amount into variable w):
    w = wiggle(1,9) – value;
    then add it in at the bottom like this:
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t) + w;
    }else{value + w}
    Dan
  • Sean Platt
    October 16, 2015 at 5:38 pm
    Dan, thank you so much. I hope I can get my head wrapped around this better someday.
