Activity Forums Apple Final Cut Pro Legacy combining audio and video files
  • combining audio and video files
    Posted by Venezia79 on August 30, 2006 at 12:55 am
    hey there,
    i’ve made subclips of my video source file and organzized them into bins/folders. i also have sound files and would like to sync and attach them with the video – what is the best way to do this?
    using fcp 4.5hd, osx 10.3.9…
    thanks!
    -mike
    Lars Apneseth replied 20 years ago 2 Members · 1 Reply
  • Lars Apneseth
    September 10, 2006 at 11:30 am
    Hi. I’m also syncing audio and video, for the first time in FCP – I usually work with Avid. Did you find out the best way to do it?
    I know you can use the “merge” function if you already have divided the video into takes. But I think it is usually better to capture the whole video tape in one clip, insert it into a new sequence, do the synking – and then make subclips of the takes. This way you’ll already have a convenient preview of all the material from that tape.
    Problem is I haven’t found in FCP a way to make sub-sequences into sub-clips!
    Have you got any ideas?
    Lars.
