Activity Forums Adobe After Effects Expressions combining 2 things
  • combining 2 things
    Posted by Gunnar Kordestani on December 22, 2007 at 7:52 am
    hello everybody,
    I want to apply to the z-position of a Layer
    1. same values as the layer above, but a little less >
    2. same values as the layer above, but a little later
    1.
    x=position[0];
    y=position[1];
    z=thisComp.layer(index-1).transform.position[2]/.9;
    [x,y,z]
    2.
    x=position[0];
    y=position[1];
    z=thisComp.layer(index-1).transform.position.valueAtTime(time-1);
    these expression do either one of the desired things, but I can’t figure out, how to combine them…
    how would you do?
    also I wonder, why in the second one the ending [x,y,z] is not accepted but requiered in the first.
    thanks
    Gunnar Kordestani replied 18 years, 8 months ago 2 Members · 2 Replies
  • Filip Vandueren
    December 22, 2007 at 8:47 am
    Hi Gunnar,
    combing the two would be:
    x=position[0];
    y=position[1];
    z=thisComp.layer(index-1).transform.position.valueAtTime(time-1)[2]/.9
    [x,y,z]
    your second question:
    since you only want to change the z-part of the position value, the x, y and z are stored separately as numbers, then recombined as a list with 3 values.
    That is what the position property of a 3d layer expects as the result of an expression: [x,y,z]
    In your second example, you’ll see that in the variable z you were actually storing the entire position variable, not just the z component. [2]
    Sticking that in an array would give something like [x,y,[x2,y2,z2]], and you would get an error.
  • Gunnar Kordestani
    December 22, 2007 at 2:52 pm
    that’s it, great!
    thanks a lot !
