Activity Forums Adobe After Effects Expressions Combinig expressions with keyframes
  • Combinig expressions with keyframes
    Posted by Yair Neumann on January 23, 2009 at 1:48 pm
    I have a question that’s been puzzling me, how can I combine keyframes with expressions?
    Basically what I need is to make a photo’s opacity wiggle, but I only want this to begin at at a certain frame in the composition.
    Any help would be much obliged
    Filip Vandueren replied 17 years, 8 months ago 4 Members · 3 Replies
  • Paul Hennell
    January 23, 2009 at 3:26 pm
    Might be other better ways to do this but I’ve used this in the past –
    [Add Checkbox expression control]
    if (effect("Checkbox Control")("Checkbox") == 1){
    wiggle(10,100);
    }else{
    100
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
  • Chris Arnold
    January 23, 2009 at 3:41 pm
    timeToStart = 2;
      timeToStop = 4;
      if ((time > timeToStart) && (time < timeToStop)){
          wiggle(3,25);
      }else{
          value;
    Also, you can tell expressions when to start or stop via time or frame numbers.
    Here’s a link to adobe docs where they have info on how to stop and start a wiggle by just typing in the time you want it to stop and start. Same as code I placed in here.
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/help.html?content=WS22BD9B45-A813-4b13-996D-A4561D108A8C.html
  • Filip Vandueren
    January 24, 2009 at 12:51 am
    In the case of Wiggle, you could also add a Slider Expression Control, and use that value as the wiggle amount.
    So you can keyframe from 0 (= no wiggle) to 100, instead of suddenly switching off the wiggle which will most likely cause the layer to jump from one position to another in 1 frame.
