Activity › Forums › Adobe After Effects › Combination of 3D layers togeder
  • Combination of 3D layers togeder
    Posted by Zdenek Dovole on October 12, 2007 at 5:37 pm
    I had created 3D compact object using 3D oriented PSD files. This 3D object appears correctly, when is turning in 3D space. But, when I copy this object {i have two, the same objects in one Composition}, the appeararytunce of this objects depends on they layer order. When I am moving with camera and the 3D objects overlaps each other {stand in line, when one is behind the second},the object, that is in first layer, is visible, even it stands BEHIND the object ftom second laer.
    But I would like, when I am moving the camera, to see the two 3D objects like in real. And not to see back object through the front one.
    I hope is possible to understand… :-}
    Thank s lot.
    Zdenek Dovole replied 18 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
