Activity Forums Adobe After Effects Colour that changes when the bass from the music hits
  • Colour that changes when the bass from the music hits
    Posted by Jonathan Sikkema on July 27, 2015 at 2:50 pm
    Hello people off the internet 🙂
    I want to make something but i dont know how…
    I will post a video link so you know what i mean: https://www.youtube.com/watch?v=MPI9kdP6n6o
    I can make the spectrum and everyting else accept that color changing on the music. Can someone help me with that?? 🙂 I have adobe after effects CS6
    Have a great day and thanks in advance.
    John Cuevas replied 11 years, 1 month ago 3 Members · 4 Replies
  • Richard Herd
    July 27, 2015 at 10:03 pm
    That requires an expression from the math and design guru, Dan Ebberts.
    By DAN EBBERTS
    //change colors to the beat
    threshold = 10.0;
    colors = [[255,205,47,255]/255,[213,116,45,255]/255];
    audioLev = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    above = false;
    frame = Math.round(time / thisComp.frameDuration);
    n = 0;
    while (frame >= 0){
    t = frame * thisComp.frameDuration;
    if (above){
    if (audioLev.valueAtTime(t) < threshold){
    above = false;
    }else if (audioLev.valueAtTime(t) >= threshold){
    above = true;
    n++;
    frame–
    colors[n%colors.length]
  • Jonathan Sikkema
    July 27, 2015 at 11:26 pm
    Thanks for the reply!
    I am trying to figure out how it works but till now i havent done that yet…
    Can u say me what i need to do so i can get it to work??
    Thanks in advance!
  • John Cuevas
    July 28, 2015 at 2:51 pm
    Seems to be a line missing from the expression that Dan originally posted. To use this expression, you need to select your audio layer, go the “Animation” drop down > Keyframe Assistant > Convert Audio to Keyframes. That will drive your color changes.
    Then add a fill to your spectrum, alt + click the color stopwatch and add this expression. In my example I have it set to 3 colors, RGB, you can add more colors by adding a “, [0,0,255,255]/255]” to the end of the expression, just make sure you take the last bracket ] off the previous color.
    threshold =10.0;
    colors = [[255,0,0,255]/255,[0,255,0,255]/255, [0,0,255,255]/255];
    audioLev = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    above = false;
    n = 0;
    while (frame >= 0){
    if (above){
    above = false;
    above = true;
    n++;
    frame--
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    July 28, 2015 at 2:54 pm
    Here’s a simple project(minus the audio) that shows how you place the effect and expression.
    9088_audiobeatexrpession.aep.zip
    ThinkCK
