Activity Forums Adobe After Effects colour management workflow – AE -> FCP
  • colour management workflow – AE -> FCP
    Posted by Paul Rijkaard on May 17, 2010 at 1:57 pm
    I am working on a project between Final Cut Pro and After Effects using pro-res (normal quality) footage at 1080 25p.
    When I make a comp in AE the footage appears to be brighter – as if AE has converted the colour profile (perhaps to adobe RGB??).
    How can I render this footage out of AE so that the colour brightness range is as close to the original footage as possible – e.g. to colour match when slotting it back into an FCP sequence
    many thanks
    Paul
    Todd Kopriva replied 16 years, 3 months ago 2 Members · 1 Reply
  • Todd Kopriva
    May 17, 2010 at 3:05 pm
    You didn’t say which ProRes codec you were talking about or which versions of the applications you’re using, so I’ll take a guess and point you to this article for ProRes 4444 and CS4:
    “ProRes 4444 colors and gamma shift when working with After Effects and Final Cut Pro”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
