Activity › Forums › Apple Final Cut Pro › Colour/ hue shift in video footage
  • Colour/ hue shift in video footage
    Posted by Rafe Gibbons on February 22, 2016 at 1:08 pm
    I’m having an issue with the color of my footage.
    Very suddenly during the clip, it shifts from green to pink and back again.
    The clip below shows an example – if you look at the first picture of the girl’s face it dips into green then pink…
    https://www.youtube.com/watch?v=7RasEuIzWWA
    The factors at play here are:
    Filming on A7s – XAVCS mode
    Filming in Slog2picture profile – using an Slog2 to 709 LUT converter within fcpx
    Filming with 28-70 zoom kit lens
    Editing in Final cut pro version 10.1.3
    Exporting as Apple Prores – but same occurs with h.264
    Thanks for any suggestions as to what the problem could be!
    Production Company
    London
    Richard Jacana replied 10 years, 6 months ago 3 Members · 2 Replies
  • Jeff Kirkland
    February 28, 2016 at 6:05 am
    What version of OS X? I vaguely remember that sort of thing happening in older versions of FCPX when OS X moved to AV Foundation but from memory it was happening when plugins were applied rather than just a straight export. Could be related though as you are running a fairly ancient version of FCPX.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Richard Jacana
    March 15, 2016 at 6:42 am
    Not that this is directly related to your problem but I noticed when using a LUT in FCPx when the footage is paused vs when playing the footage has a greener cast to it. Probably some bug. Not sure why your issue does not effect the entire clip though.
